5 days for a 3 bed house.
1 Power off - all fitting removed- with hammer etc. no fiddling with screws
2 all chases done
3 all cables in
4 all accessories back boxes fit and plastered in
6 all accessories fitted
7 CU on and done and tested dead and live
clear up get out get paid
oh and give Mike a Like
If you do regular re-wires 100% get a lad / labourer in to do the chasing , boxes , drill out joists etc a few days in advance. Let the dust and dirt settle.
you then rock up and can wire , box , tube and stay nice and clean...
Have a look at this, go from about 5 mins 20 secs in...
I was just looking at that video yesterday! I'll give a review myself on here in a few months when I've used it a bit.
Rather than employ someone could you pay for a mate from an agency for 2-3 days? Just to get the cables run in as that's always the tricky part on your own- up and down stairs a hundred times and them in and out the loft for the lights! Don't know how expensive it would be or even if you can get labour for that short a term but then you could carry on rest if first fix and then second fix by yourself if that's what you prefer.
I may think about that as lots of you seem to say the same thing, i.e get help.
I recommend learning a few emergency plumbing moves before breaking out the chaser, just for when the inevitable happens ;)
Definitely! I have no idea how to fix a pipe if I go into it. Done it twice now and each time I've had a plumber on hand, but one day........
Are these lived in or empty property rewires you have been doing
A mixture.
Chase out, oval conduit and secure with screws just pinching the oval.
Why not use the conduit clips Lee? It would be the same time to screw a clip in as to just screw a screw in?
25mm oval fits perfectly in the chases. Either screws or nails to hold it back. Much easier than capping.
Best way to speed up is to get some help with running cables and chasing especially.
Why 25mm? I'm guessing 2 x 2.5mm fit in a 20mm oval?
2 all chases done
3 all cables in
Are the numbers relating to days or order Vortigern? Is this by yourself or with a helper(s)?
As above, a number of you have mentioned help with the chases. I think it's time I gave it some thought.
Numbers are order of events. Mostly on my own, someone chasing mostly as helper.
Reactions: HappyHippyDad
They do, but need to perfectly straight as you feed them in- 25mm is just easier for 2x2.5mm and needed for 6 or 10mm
I am intending to try it with wall dog and no plugs just to speed things up a bit more ?
Depending on the strength and condition of the existing mortar, you can sometimes get a good fix with clout nails (the thicker 3. something mm ones). Saves on drilling and plugging- not sure what wall dog is by the way
Reactions: Baddegg
Appendix E of the OSG gives cable capacities of conduit.
Wall dog....screws that don’t need plugs....quite pricey...but that sounds like a customer problem ?
Reactions: loz2754
always used galv clouts 1.5 inch into mortar, then on with a few blobs of bonding. Sets fast next day fill in with bonding the skim next day.
Also goes without saying a decent twin disk wall chases and strong hoover attached are an absolute must..
I remember back in the 1990s doing my apprenticeship having to stitch drill chases then knock out the middle with a hammer and old beat up wood chisel...
Reactions: loz2754
How have you found those walldogs generally @Baddegg ? I find them useful for fixing direct to plasterboard, and they're supposed to be good direct to thermolite block. But I haven't found them to be much use in anything harder.
Reactions: suffolkspark
Don't understand your post Dusty, the hooks I put the link up for are to hold conduit in the chase?
The post above mentioned T&E and I was asking why you would put T&E in Conduit rather than single core.
Love em mate, drill a smaller hole than stated and use an impact you’ll get a good fixing into brick work for back boxes, and agian once the bonding goes in and round the box it’s going nowhere
This French guide on max amount of cables in Conduit may be of help, but may not be within the UK regs:
HappyHippyDad
Supporter
Gloucestershire
Any advice on rewires?
HappyHippyDad,
brianmoooore,
