I use a Nilfisk aero it switches on when the tools switches on. screwfix do themwhat vacuum you use?
I use the same as Vortigern. I have only just bought the Nilfisk aero 26 https://www.screwfix.com/p/nilfisk-aero-26-21-pc-1250w-25ltr-wet-dry-vacuum-cleaner-240v/66972My ‘Mr Cheap Chases’ works well an nothing stops it, but it can’t compare with noise and dust performance of these Bentley models, I think. I only use (or is that abuse?) my general purpose Henry to deal with the dust and that could also be part of my misery.
@happyhippydad and @Vortigern - can I ask what vacuum you use?
That's good to know! I'll stick with a bag, thanks.I have used it without a bag to pick up rubble. Probably shouldn't have as when I used it the next time in my house fortunately, a giant puff of dust came out. It goes through the motor that way. Think I might have lost the cover for it. But I put bag in now. Of course you don't use bag with water pick up. So if you find out, tell me please!
Looks like you do just as you said for water https://consumer.nilfisk.com/en/cases/About-wet-and-dry/Pages/WaterSuction.aspxAbout the bag I mean, the bagless bit, the question you asked.
Just remember that with the Erbauer... you need to drag it, rather than push it. I read a review where the chap was complaining that all the dust gets blown out of the slots you've just cut ! With some chasers, the blades rotate the other way.Thanks for the review on that. I am so glad the sockets weren't wired horizontally. I have just bought a cheap Erbauer and will be using it tomorrow, will tell you how I get on with it. Kitchen first fix. I looked at all the options and thought I was not prepared to pay £400 plus for the makita. At the end of the day it is just a double diamond wheel to cut masonry. Let us see if it works out then. I do have an industrial hoover for the event. Generally I have found Erbauer to be pretty good tools. Lets hope I am not disappointed.
At that sort of money I'd never use em... they'd be in a display cabinet in the lounge instead !I love this tool...at least I would if I could afford it...
https://www.zoro.co.uk/shop/hand-tools/insulated-tools---sockets-spanners-and-wrenches/set-of-18-socket-wrenches-1"-1.1/8"---3.1/8"-non-sparking-cu-be/p/ZT1163813P?utm_source=google&utm_campaign=pla+|+Hand Tools&utm_term=ZT1163813P&utm_medium=pla_css_1&targetid=pla-877905861044&loc_physical_ms=9046942&dev=c&gclid=EAIaIQobChMI-_XNjM2W7QIVi_jVCh3JZQcREAQYBSABEgJsT_D_BwE
That's an interesting point Zerax. Are you saying that there shouldn't be too much dust with a wall chaser and dust extraction unit? It makes me think I may have been doing something wrong. I'm sure the metabo is a push rather a drag though. Also, it must be working as the amount of rubble it hoovered up was pretty incredible. Just still a lot of dust!Just remember that with the Erbauer... you need to drag it, rather than push it. I read a review where the chap was complaining that all the dust gets blown out of the slots you've just cut ! With some chasers, the blades rotate the other way.
I think you're right... the metabo is a pusher not a puller. I think the amount of dust is driven by how good your vacuum is... I use a Fein Dustex, which works great... and for max suction, I'll treat it to a fresh bag too !That's an interesting point Zerax. Are you saying that there shouldn't be too much dust with a wall chaser and dust extraction unit? It makes me think I may have been doing something wrong. I'm sure the metabo is a push rather a drag though. Also, it must be working as the amount of rubble it hoovered up was pretty incredible. Just still a lot of dust!
being Scottish. you need to use your own. save it and then root through it for the odd 5p.Just use the customers vacuum cleaner. Cheapest option. It is their mess you’re cleaning up after all.![]()
