Discuss Safe isolation in the UK Electrical Forum area at ElectriciansForums.net
Guide 2
Guide 2
Thanks. Would NICEIC accept this as i am looking to become a domestic installer?
Think of it not in terms of meeting a specific body's requirements, think of it in terms of keeping your own (and other's) body alive.
Apprentices get the procedure drilled in for that reason, and on practical exams not doing it 100% is a fail for precisely that reason. No one wants to have to explain to friends, relatives, and the judge at a fatal accident inquiry what happened.
Reply to Safe isolation in the UK Electrical Forum area at ElectriciansForums.net
Hi, after some discussion with electricians, does removing a 16A or 32A socket constitute safe isolation? I understand that removing the socket...
Hi all, if I cannot access the line side of a crabtree 100A DP main switch. Would someone enlighten me how to conduct safe isolation on this...
If there isn't a 2-pole isolator there already, I usually get the client to arrange to get one fitted before I do a board change, either through...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
I'm after advice on how best and safely to do a friends Fuseboard upgrade. Current setup is a Wylex 6 Way board with MCBs of 2x 6A, 2x 32A and 30A...
