T
Tilly Tyler
Help. I am trying to replace a 2 way light switch on the landing. I did not take notes of what wire went where before I took the old one off, a silly mistake. I have 2 red and 1 black wire, cannot make it work, any advice on the wiring please
you first picture shows a 2 gang metal switch.... ie, 2 switches on one plate.
the new one is a 2 way. Meaning 2 switches in 2 locations operating 1 light
The 2 switches on 1 plate is the hall the other is the landing. I cannot get the wiring correct so that the landing light can be switched on and off by either switch
If you have not changed the wiring in the hall switch, the landing switch should have black in common and the 2 reds in 1 and 2.
Thank you very much, unfortunately I also bought a new switch for the hall and didn't take note of those wires either
For the 2 way to work, you have to find out which of the wires are connected as 2 strappers, that is, they're wired directly from the landing switch to the hall switch into terminals 1 and 2.
Then you need to know which wire at the hall switch is permanently live. If you can figure this out safely, ie with the power switched off, you'll be half way there.
Generally, the forum rules don't allow us to give step by step instructions from a distance to DIYers, as there are obviously safety implications. Hence the reason for suggesting getting someone in.
Thank you
