Consumer unit / rewire
Cost me around 50 or 60 quid can't remember . I was not here, when I came home wasnt overly happy as he used white pipe outside which I think looks cheap and the light is so high I cant get the screws off the cover to change the bulb!
To be fair I think the conduit looks better than just a cable clipped to the wall, but I would have discussed options with the customer before installing it.
Is the second board fed from the first. If so the second board will have RCD protection.
just playing devils advocate hear.
I think the conduit looks nice neat and tidy. Seems a good job. Did you specify height of light?
if you where not there, who was there to answer any installation queries?
again just playing devils advocate.
id be happy with that installation.
Dont mind it but I think black would have been less in your face. He never mentioned doing it like that. Originally was to clip the cable to the wall and light about a foot lower
No second board . No one am afraid he was left to do when we had just purchased it. We spoke and the light was to be around a foot lower and the hold near the door so the cable would be along the door frame then across to the light. My own fault really as I did not go after it was installed for a couple of days and well just will live with it as it was a long time ago.
An EICR carried out by an experienced competent person is without doubt the best way to go. You can never judge by just looking at an installation photos or otherwise. I have seen installs that have looked neat tidy and compliant, and then its turned out to be lethal.
As an example, a 6 year old property, client said getting shock from shower !! RCD not functioning, cpc from isolator to shower was floating, and the element had gone down to earth, plastic pipe to the shower. Said he had a tingle when in the shower and his elbow touched the tiles. His wife said she felt like it was a static shock like when you touch a car bodywork, when she turned the shower off !!
One of the worst real life examples I have encountered, and lets be honest a fatality waiting to happen.
Sorry !! I have gone off topic here but just wanted to point out what can happen and why EICR,s carried out properly are so important.
Yes 100% will be getting someone in to do as soon as possible. I'll post the report as well just so all the guys and gals who have commented can see.
For me black conduit inside or industrial. White for outside Always unless specified.
The default choice thing doesn't work for me, it's not all just about black and white. Unless your going all arty it's what looks aesthetically right for the install, it is ultimately the customers choice
I have to agree, I tend to look at the property and see what fits, such as PVC facias, guttering, drainpipes etc.
why did he not chase cable up internally and exit through the wall, direct into the outside light?
