Firstly, thanks so much to everyone for your help. It really is useful. I was probably a little mis-leading in my earlier responses. The C2 concerns relate to the existing electrics, rather than the electrics installed in the new extension. That said, prior to the EICR being done, there were no EICs of any kind for any of the electrical work done at the property and there are no EICs for the electrical work done in the new extension either. It seems the seller's Dad did all the work. He was a retired electrician, but was not NICEIC registered hence no self certification. The sellers view is that as the new extension got a completion certificate, there is no need to worry!
Ah, that's a little less worrying then I suppose. I would still go for an up to date inspection of the property prior to purchase just because a previous one highlighted potential dangers and there does not appear to be records of them being rectified. Some C2 issues can be a cheap simple fix and some could indicate the need for more extensive work.
Thanks Andy. As you say, some of the C2 issues appear minor, others are more serious (EICR says 'no verification of the earthing arrangement for this property can be made'). We know full well these issues haven't been rectified, and it was only after asking many times that they actually sent the EICR to us. So we are trying to get the seller to resolve the C2 issues prior to exchange, or to offer money off the price. I'm probably over reacting, but I don't want 2 your children living in a house deemed to have 'unsatisfactory' electrics!
The earthing issue is very fundamental and may have to be sorted out by the DNO. Our DNO do this sort of work for free within a two week time frame though.
What you have got to understand is that all electricians are giving C2's to try and get the work to fix it when the installations are perfectly safe. It's a disgraceful scam orchestrated by the government and electrical governing bodies.
No, it is only unscrupulous electricians who do this, or ones who do not understand the regs. It certainly isn't 'all electricians'.
1 - rather old thread
2 - maybe some electricians, but certainly not all. Most have ethics. I have a client base built on trust and not ripping people off.
If you’ve had a bad experience feel free to ask about it, people do stick EICRs up on here for comment, with all personal details redacted.
I’d add that if you have a look through the EICR section of the forum you will see many examples that are not competently performed, and the extent that proper electricians disagree with the findings.
As in most* walks of life, the majority of any profession are doing a decent job, and there are a few who are unscrupulous charlatans. Sadly when the law mandates something there will be more charlatans coming out to profit from it.
These forums show a lot of EICR problems but it is self-selecting: folks post here because they have some issue with it. True, there are underlying problems of different guidance being offered according to which scheme an electrician belongs to, but most folk (including those schemes) have sensible guidance that is publicly available as "Best Practice Guide #4" downloadable from here:
https://www.----------------------------/professional-resources/best-practice-guides/
If someone has concern that the coding is not reasonable, folks here will look at any (personal details redacted) report, supporting photos, etc, and offer some advice. In a lot of cases you find the original electrician actually corrects things as they are not deliberately doing it, but mistakes happen.
[*] except politicians, of course.
Is it possible the EICR relates to the original installation as post #4 implies and not just the extension in question.
Its possible the extension is compliant and the C2's relate to other issues in an existing installation?
