M
msteel9999
I'm trying to connect a spur to an existing outlet but when I use an appliance on the spur socket the rcd trips.
I've tested the rcd and it has 19 amps capacity which is as expected.
I've also tried connecting to a different socket on the same rcd and it also trips.
What I don't understand is if I use the exact same appliance on the internal socket it doesn't blow.
I've also tried using a different external socket but the same result.
I've connected the socket with a heavy duty cable and so that the original socket has three wires in each of live, neutral and earth.
Any ideas?
Cheers
Any ideas?
Cheers
