N
NickT75
I have a 17 way BG consumer unit I have set up with dual RCD. I got the 25mm tail kit, but can work out how to get 2 live tails into the bottom of the main switch to connect to the RCDs. Any ideas please?
I stupidly bought a blank unit that only came with the main switch.Can we have a photo?
normally, the tails go into a main switch, then there are made up tails feeding each of the rcds from the load side of the switch.
These should be included in the consumer unit what purchased.
I don’t think these are compulsory yet?And don’t forget the SPD
I can’t seem to find a kit for dual RCD where the lives are linked. The other thing I’ve noticed is when you bend the tails to fit them it’s difficult to not have exposed copper, as the insulation pulls away. Any idea where you get shrouds from.Well, I think you can buy a conversion kit which has the right link cables at the right lengths.
your 17 way board will only be 13 when you add in a couple of rcds
Sadly too late for that. Unpacked, knockouts removed and fitted on the wall.If i were you i would return it and buy the correct board of a different brand. Or I would use rcbos and abandon the dual RCD plan, bg ones are not that expensive.
