- Dec 18, 2011
- 5,379
- 6,731
- 405,788
- United Kingdom
A customer wants me to fit an electric heater with timer control integral to it.
There seems to be really cheap ones (screwfix) ranging up to £100's, so it's a bit difficult to make a choice. Is there anything wrong with the cheaper ones? They seem to have reasonable reviews on screwfix.
This is to heat an extension 3m x 3m. Does anyone have any recommendations?
Also, their existing plug in heater is 2kW. they don't feel that gives enough heat. However, the heating calcu;lations for a 3m x 3m come out at around 1kW max. Is this because the plug in ones just don't give as much heat per watt?
Cheers all.
Cheers all.
