Had something similar once, but with a water meter. Comparing the alleged current reading with several previous readings, then adding the normal expected usage to the last correct reading clearly showed that a digit had moved that shouldn't have.
Was sorted easily enough, but first I had to wade through multiple layers of script reading call centre staff, each slightly further up the command chain than the last, before finally reaching someone who was authorised to actually think.
40,000 units in what? 20 days? For ease of calculation that’s 2000 units a day…
A unit is a kW per hour. 24 hours in a day…
2000/24 that’s 83.33 kW EVERY HOUR!
83,333 Watts, divided by a generous 250 volts is…..
333 Amps. All the time.
Even over 60 days, that’s more than your main supplier fuse can handle.
The most important thing to do first is to stop the Energy supplier from billing the O.P
If the O.P is on a similar rate to me per kwh then the outstanding for the 40000 is around £6700.
OFGEM should be able to at least get the supplier to hold back the charge for now on the basis, as Littlespark's example, it would have been almost impossible for that usage during the period.
However just a warning,the energy supplier may argue that the O.P has been sending under readings in and the 40000 is an accumulation of the outstanding.
AS the Energy supplier have closed the case that's perfect for an OFGEM complaint as the supplier will no longer discuss it and don't appear to have made any reasonable attempt to sort it out.
Whoever fitted the Isolator also appears to have replaced the meter to consumer unit tails ((brown / blue cables) and the tails from the fuse cutout (lower right) to the meter.
As the meter and the tails to the cutout are the property of the Energy supplier then whoever did that work, which involved cutting the meter seals and moving it, MUST have had authorisation from the Energy supplier.
If they didn't get it then the Energy supplier also needs to chase up why the work was done without their knowledge, initially through the Landlord who will have paid for someone to do it.
That is possible that the digits have moved when the meter is removed from the wall , but only energy providers should be doing this. Looking at your readings it has gone back.
Do you have any past billing with the (original readings) if so take a picture plus the reading showing now include the meter serial numbers in picture and on your bill.
Having said all this they should have actual past readings anyway
The power company have my meter reading history going back years as I’ve been with them a long time and I sent them a photo of the reading when I noticed the discrepancy.
They kept asking me for a photograph of before the work but neither the housing association or the contractor have one and I pointed out to the power company that I don’t regularly take photographs of my electricity meter. They insisted they needed a photograph and closed the investigation but citizens advice and consumer advice Scotland both say that my meter reading history should be sufficient evidence.
The position of the Red sticker (for smoke detector?) on the trunking under the consumer unit and meter in the first photo is under the corner of the meter and on the second photo under the new isolator with the meter moved to the left.
The meter has most definitely been moved by whoever fitted the new isolator so will have been lifted off the wall and most likely laid on the floor. There will also be evidence of old screw holes for the meter fixings in the back board showing it's previous location.
This may have been what's disturbed the reading and together with evidence of previous energy usage should be enough to cast doubt on the current reading.
Contact the your Energy supplier and tell them you're raising the issue with Ofgem and then raise the issue with Ofgem.
I’ve already sent all this to the power company and used that exact explanation to show the meter had infact been moved. At this point the contractor finally admitted they had moved the meter.
However, power company are insisting they need a before photograph. I haven’t got one and said they have my meter reading history.
New tails as well to the cut out
Hand it back to your landlord as he got the works done so in theory his issue
I have told the landlords numerous times that it’s there issue to resolve but they have left me to sort it. Citizens advice and consumer advice both said this too.
I’ve raised a formal complaint with the landlords regarding this.
The meter reading has gone round the clock if that actually happened through usage which it didn't assuredly
77>>> 17 is where u get the 40k
Yes this is where the 40,000 figure comes from.
I said to the power company the reading has gone backwards but they said no it’s gone forwards by 40,000 but that does seem unusually high.
There will be a date under the glass on the face of the meter, probably month / year.
If that's over 20yrs then the meter is out of calibration and should already have been changed.
Power company advised it was installed in April 1988.
Tape a strong magnet to the front of the meter to slow the disc down enough to compensate for the 40,000 units..
I didn't just say that.
Its going to come down to the electrician taking it off the wall, which he shouldn't have in the eyes of the supplier. Hopefully, the supplier will realise this and not charge you.
Keep at them, get OFGEM involved, dont pay, its not your fault!
Please keep us advised of the progress of this. Its going to be an interesting one.
Thanks, I’ve contacted power company again and raised the meter might have been laid down and the numbers could have moved. Waiting on their response. I’m hoping common sense will prevail but it looks like we’re heading to deadlock!
You are responsible for YOUR actions- it is NOT your actions that have caused a problem here.
Your landlord and their contractor have caused an issue and THEY have moved the meter (not your meter- the suppliers meter)
Who are the supplier?
Before you call again get a VOIP number that allows call recording (I use Net-Telco) and call again.
Let them know you want to raise a formal complaint and that you are recording the call, this usually sharpens their mind
I’ve tried getting the landlord to take responsibility but they are leaving me to try and sort it out with the power company. I’ve raised a formal complaint with the landlord about it too.
Doing everything by email so I have a paper trail of everything.
I’m glad to hear you got it sorted out. It feels like common sense is sadly lacking here and I’ve been losing hope of ever getting it resolved. Hopefully I’ll get there in the end though.
Thank you for this. That might be useful for me to tell the power company although I expect they should already know that. The word impossible has been used a few times but the power company have just said it’s unusually high.
