Just seen these in a TLC advert for "221-2411 Inline Lever Connector":
Looks like a handy thing for some situations.
I found a kitchen recently that had lots of these:All they need to do now is design a 3 way one and a small maintenance free box for it, then you can use them when people drill through a cable and the cable can't be replaced.
The containment for them was expanding foam filler.![]()
In Line Spring Lever Connectors 3 Pole Trade Pack 32A | Toolstation
Use these 32A spring lever connectors for an easy, fast-fit connection. The levers are a real time-saver, and the compact design makes them easier to work with in confined spaces.• 3 in 3 out inline lever connectors• Spring levers for easy, fast-fit connections• Colour-coded for live, neutral...www.toolstation.com
I think that was the Wago connector that was Chinese copied... before Wago even made it ! Looks like Wago have now decided to make em...Just seen these in a TLC advert for "221-2411 Inline Lever Connector":
Yep, still not aware of an official Wago version.I think they are still the unbranded ones. Not Wago.
I've used them - they are fine.
I've never quite understood the 4mm in brackets. Is that if you have iron-bru and push very hard?!
I have seen that with DIN terminals where the larger size is single solid core, and the smaller the stranded size. Odd, as I would have expected it the other way round!I've never quite understood the 4mm in brackets. Is that if you have iron-bru and push very hard?!
Official 100% wago have them in Denmans and Rexel.I think they are still the unbranded ones. Not Wago.
