All they need to do now is design a 3 way one and a small maintenance free box for it, then you can use them when people drill through a cable and the cable can't be replaced.
I found a kitchen recently that had lots of these:
The containment for them was expanding foam filler.
Tel likes those. Probably not with the foam though!
I think that was the Wago connector that was Chinese copied... before Wago even made it ! Looks like Wago have now decided to make em...
I think they are still the unbranded ones. Not Wago.
I've used them - they are fine.
Yep, still not aware of an official Wago version.
I've never quite understood the 4mm in brackets. Is that if you have iron-bru and push very hard?!
I have seen that with DIN terminals where the larger size is single solid core, and the smaller the stranded size. Odd, as I would have expected it the other way round!
Presumably no data sheet for those?
I find that careful use of a hammer against some sort of anvil (like a lump hammer)... can make a solid round cable almost square, to better fit the hole in a push connector.
I noticed on CEF website that carriers are available to hold up to five of them side by side. I guess you have to supply your own enclosure 🤔
