PS, once you've sorted out your blown fuses, afraid to say a new fuseboard upgrade might be recommended. Just saying
Or the plug-in Wylex breakers instead of the fuses as a least-worst option if a new CU (consumer unit = fuse box) is unaffordable.
No, they are not as good as a new board with RCD/RCBO, and the possibility of the new CU coming with other faults being fixed, but they sure beat having to change wire in the dark, working out which one has gone, or the risk of inserting a fuse on the a live fault.
We have not long since moved in so there's a few things that need doing.
The lack of lighting became a priority when it went out.
I remembered on my way out that it's a bank holiday and most places are shut.
I'll try tomorrow.
Let us know how you get on.
If you need professional help then some member on this forum might be local and able to do so. Don't post personal information, just an approximate address (e.g. town or postcode) and then if anyone here can resound they can get in touch via a private message, etc,.
Welcome to the forum mate.
The OPs info says he's from Warrington.
