Hi guys
Recently I've had a wall paper steamer plugged into my upstairs ring main and noticed after several minutes a fishy smell which was the result of a burnt out live pin in the socket. To add add main breaker did not trip at this point or even the plugs 13amp fuse (could you advise as to why?)
Assuming it was either a faulty plug or socket I replaced both. (Socket connections where fine)
I've since tried the steamer again for a few minutes, removed the plug and the pin was warm/hot
Unsure if it was the upstairs ring main issue I tried it on the downstairs ring main and same problem.
I assume now this issue lies with the appliance but I'm unsure as to what is causing it and wonder if you guys could give me some knowledge. I assumed something to do with current draw.
