M
Martiv
I’m welding and have a cable blue 2.5mm 3 core 10metwrs to reach my shed
the plug and socket I got to wire on them biggest hardware has says 13amp but then says 1.0-1.5mm wire rated
online said I can stil do it but it’s a squeeze is that acceptable ?
I use 2.5 for it stops volt drops while welding you can see it in the end weld teated it from wall on my extension and on friends 2.5mm and yeah wall and his cable weld the same my old 1.5extension has a drop you wouldn’t know until you compare welds
so I got the blue cable but can’t find plugs n socket that say 2.5mm in hardware store do I wire the ones I got by master plug a 2 socket and a plug 13amp heavy duty
