Hello -
I am a new member (and just a UK householder rather than a professional) and have a couple of questions about domestic LED bulbs. I want to update many bulbs in my house and looked at the web sites of B&Q and Wickes. Both sites show bizarre variations in energy efficiency ratings for virtually identical products, and very poor ratings (E, F and G) for a large number of their LED bulbs. For example, at B&Q they have GU10 4.5w LED bulbs (non-dimmable) in cold white and warm white. The cold whites are shown as rated at F, while the warm whites are at A (see screenshots attached)! Surely this can't be correct? They also both show a wide range of LED bulbs with very poor ratings - surely all modern domestic LED bulbs must be in the A range? I asked both firms for their views - B&Q said they didn't know (!) while Wickes simply sent me a customer satisfaction survey in reply!
Thanks.
The efficiency rating quoted is a measure of how well the individual device converts electricity to light.
It's efficiency is down to quality / design of the electronics and the quality / design of the reflector / enclosure, there's plenty of scope for variation beteween individual devices and manufacturers.
That's not the same as the comparison of how well LED lamps in general compare to older halogen, etc, lamps.
Thanks for the quick reply. Given that the products are identical and from the same manufacturer at the same time, with identical specifications except for colour temperature, would you really expect one to be at A rating and the other at F?
So many websites are left lacking on the technical product detail at times mainly IMO because either the website designer has a limited technical knowledge of the product or product type or they have been given the incorrect details by a non technical sales person and neither have noticed the inconsistant infomation
A month ago, I bought a new fridge/freezer, and while selecting the one I wanted, was appalled by the low efficiency ratings that most had. A bit of research found that the classifications had recently been changed, and that a model that was previously 'A' rated was now classified as 'E'.
I think you may have just found old packaging and new packaging.
The filament style LED lamps are more efficient than the sort where part of the globe is opaque plastic and the other part transparent, by around 10%.
This could be nearer 200% if the manufacturers were allowed to. Google Philips Dubai led.
Yes - what I also should mention is that at least one product has a summary rating (the one shown on the web page by the product) of F, while the accompanying detailed specification/product sheet (which has to be clicked on to read) for the same item says it is A! I also must say that I have noticed a very similar set of discrepancies to the B&Q ones on the Wickes site for their LED bulbs. I am coming to suspect that the manufacturer's information is wrong (Chinese?) and that both firms have simply taken them at face value, which is pretty poor. I would expect all LED lighting products to have a very good efficiency rating, and I certainly wouldn't expect identical ones (except for their colour temperature) to have ratings at each extreme of the spectrum!
It depends how the ratings are set.
It could be for LED regardless of colour temp.
or it could be for each colour temp.
The efficiency result could be different depending on the efficiency test.
The transition from 'old' labelling to 'new' labelling is described on the (random) web page below, along with how the calculations are done.
They have changed the 'granularity' of the scale so that small variations in LED efficiency show up as a larger change in the category, so I feel one gets an overly pessimistic view of energy efficiency for some.
I don't think there is enough difference between brands to make energy rating the main buying criteria - but happy to be proved wrong.
I would be more concerned about lifetime/reliability, which seem to be gleaned through experience rather than manufacturers claims. For example, for spotlights in a lofty ceiling where access is difficult, I use Philips, not Diall or Tesco's.
The link above says that there shouldn't be ANY LEDs classified as A or B, until future development produces some, so, to me, that confirms that the A rated ones in the OPs pic are old packaging.
OK, thanks. It isn't the packaging that I am looking at, just their web site. I have asked B&Q why they have such misleading, and often wrong, information, but I expect nothing of use from them, given their responses so far. As I previously said, at least one item (and I suspect many more) has the detailed on-line spec. sheet showing A, while the on-line (same page) summary for the same item shows F! To draw a comparison - say I buy a car that is sold, according to the advertising blurb with 100mpg, but when I look at the owner's detailed manual it tells me it achieves 40mpg (or even vice versa).
Anyway, I have put the case to Trading Standards to see what they say. At the moment, at the very least, it's a minefield of confusing and conflicting (and downright wrong) information which does nothing to help people decide to switch to LED. BTW, so far, B&Q have repeatedly told me to take it up with my local store (which is utterly missing the point that it is the web site that is the issue, not the local store!) while Wickes have simply sent me a Customer Satisfaction survey without mentioning the issue raised at all! A pretty grim reflection on both firms' customer services quality.
Many thanks to all for your responses.
Good points. I have recently installed some Wickes LED GU10s, and one has already failed. Of course I threw the receipt away after a few weeks so they get away with poor quality being unchallenged. For all bulbs I buy from now on I will keep the receipts and make sure they honour their life-time promises.
Here's another one - a Wickes product, scoring only E but described as "energy-efficient" in the blurb. If I'm a customer who is unaware of the apparently very finely granulated new efficiency scale it makes no sense - it can't be both near the bottom of the efficiency scale and energy-efficient!
Here's another one - a Wickes product, scoring only E but described as "energy-efficient" in the blurb. It can't be both!
Yes it can - with the revised LED figures. E is quite good. Not the same 'E' that is applied to fridges etc. or Energ Efficiency of houses! I mean if you have in your head that D and E are poor figures, they are still very efficient figures for lighting, compared with halogen or CFL etc. It allows for even more efficient lighting to come along in due course.
This is my take on LED efficiency ratings:
I think the best you are likely to get at the moment is a 'C', ranging down to 'F' and 'G' for poor!
Any claims for A++ etc are the old ratings pre-2021, and should have been updated.
There's info about those new ratings in the link I posted.
Surrey, UK.
UK - LED Bulbs Efficiency
Lighting Forum
Deepgreen,
brianmoooore,
