Hi all, not a housebasher here, so don’t hate. Wiring my house and need advice. Want to mount the CCU just below the ceiling and bring the cables from the floor above. How do a nicely bring the cable off of the beam so they’re on the wall and then will go into the back of the fuse board? Pics attached
I assume the cables aren't dropping behind the beam so they drop down the brickwork.
I’m going to be the daft one for saying it’s a bit high for a Cooker Control Unit
Consumer Unit. CU… not CCU
Although we can help with some aspects, even a bog standard house rewire can kick up a few problems if you’re not used to the work.
Ask anything, and try not to be put off by some comments.
I do agree with mounting the CU at a more suitable height.
