- Aug 7, 2018
- 13
- 6
- 33
- United Kingdom
- Electrical Enthusiast (Unqualified Hobbyist etc)
I discovered a blank face plate in our large food cupboard and thought- ‘if there’s wiring behind this then I could put a little microwave in there’
There is wiring. (See horrible photo) so I will wire in a single plug socket there.
Being a novice I wanted to check the following-
After isolating power I will attach the following to their respective holes in the outlet:
Brown - live
Red- neutral (I’m used to being blue?)
Green yellow- earth
Question- I notice the wires are doubled up together in the terminal blocks. Why is this? Cos they come from different sources? If so why not just bring the power from one source?
I’m assuming I attach each pair of wires as one into their respective holes in the new outlet I will put in.
Thanks in advance for any advice that will potentially save my life
Brown - live
Green yellow- earth
