Light switches (at least from that era) tend to only have a live coming in and a live going back to the light (known as a switched live). The red tape around one of the wires is the way switched lives are marked, and a requirement of the wiring regs. To power anything you need a neutral, and there isn't one. Just because a wire is black doesn't mean it is a neutral. So as already said above, attempting to connect a socket there simply won't work.
The wires look like they are an extension to another light switch, i.e. the light switch was moved and those connections are still live and needed. This is reasonably likely. Doing anything at all to that wiring without testing it first is dangerous and may well stop another light switch working.
There are indeed some situations where a socket on a lighting circuit is feasible but as it wouldn't work anyway, and it wouldn't be suitable to power a microwave I won't waste time talking about them. The article you linked to doesn't even entertain the idea that there isn't a neutral at the switch, apart from saying "You can plug something into the socket to see if it’s working.".
Even it if were all possible there are other considerations when adding sockets, including ensuring RCD protection which is something that many houses lighting circuits do not have.
Most of the above has been stated in this thread already, I'm really just consolidating the answers for you. I'm afraid it's a complete non-starter.
If you need a socket for a microwave just ask a sparks how difficult it would be to add one.
I think that explains the situation perfectly- thanks for articulating it so well and helping me understand.
I’ll see what a local electrician will quote.
Glad I came on here and didn’t attempt anything daft…
