Discuss What do we think the red button does? in the UK Electrical Forum area at ElectriciansForums.net
happysteve
Supporter
The device on the right is an RCBO. The orange button at the top is the usual test button. What do we think the small square red button does?
There was a post on here a couple of months ago where someone had an 'extra' button on a RCD or RCBO.
Can't remember for sure, but IIRC, which I probably don't, it disabled the RCD.
Yes that wasn't so long ago they couldn't get it to trip because it was disabled.
I removed the MCB bit from the RCD bit. Huh.
When I move the lever on the side, the button pops out
When the button is popped out, the MCB bit won't fit flush with the RCD bit
So does it indicate whether it's a RCD trip or a MCB trip? Could do with incorporating into UK RCBOs if it does.
Ooh interesting! Maybe that's it!
The lever on the MCB bit moves the internals... It's possible that an over-current moves the internals in a way that will pop out the button via the side lever (as well as tripping the front lever down).
Thinking about it, it must be the other way round.
The RCD bit, when triggered by a fault, moves the little lever on the side of the RCD bit, which then pushes the internals of the MCB bit, which disconnects the line (L). I suspect at this point, the little red button pops out.
So you'll need to push the button back in, before you can reset the MCB.
Now the little diagram on the front makes sense, too!
But it does tell you whether it's the RCD that has tripped, or an over-current.
Huh!
So I guess it's a single pole device (like most single module "full height" RCBOs), just made in a modular way.
Reply to What do we think the red button does? in the UK Electrical Forum area at ElectriciansForums.net
Woop woop just need sort the orange in the logo out, make it red. What do you think? It's a bit bright lol
I sorted the fault fairly quickly as it happens but only because I'd come across it once before and at the time a few people said it couldn't...
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Looks very strange to me. Obviously had a new fuse carrier fitted to it at one point but the two cables on the left go to the meter as normal...
Just wondering what this might be. It was a brand new Schneider RCBO fit into an older Square D board. RCBO fit on the non RCD side. Everything...
