Discuss Smileys or no Smileys. that is the ??? in the Electricians Forums Suggestions area at ElectriciansForums.net
telectrix
Mentor
if I open the Smiley drop box from the options, it's blank, not a smiley in sight. any suggestions???
If you are using windows then while the curser is in the chat section, just right click the mouse and then pick Emoji.
I've noticed that too.
All I can do is :)-and :cool: .
So all I can be is cool or happy or both.
I've discovered a way to do it!
The smileys don't work on this site, so you can't just click on the smiley icon above where you are typing (although you used to be able to a short while ago) You can use your own emojis though. I'm using a laptop. Right click and select emoji! 😊😉👍👌
They dont look as good as the site ones though 😞
Site emoji = :)
laptop emoji = 🙂
This is getting very technical.
smiley GIF by Shaking Food GIFs
Reply to Smileys or no Smileys. that is the ??? in the Electricians Forums Suggestions area at ElectriciansForums.net
I have got these questions on 2391-52 inspection and testing but can't remember option of 1st two questions. Please any suggestion will be...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
I have a socket in by bathroom vanity unit, .75m away from the edge of the bath. The vanity is completely enclosed with a sink on top and doors...
Would any fellow electricians consider using an open PEN device to protect a metal trailer used as a "Canteen". It is likely to be often connected...
Hello folks, So my van got found after being stolen ;D Now I'm installing my own alarm on the van which is triggered when a door is opened. Im...
