Incoming supply on our job comes into the building and then the tails from which go into a switched isolator with 200A fuses fitted.
No idea what size the incoming fuses are or incoming conductor sizes. Would have to contact the DNO but not sure whether they would give that info to anyone or how long it would take for that matter?
The 200A fuses feed a busbar chamber which we are tapping off with 70mm tails and 35mm earth to feed our DB.
Can our bonding be sized from that - 25mm?
Would 16mm suffice?
Would 16mm suffice?
