right off i go on a rant about landlords and there complacency regarding periodic inspections.
they are not on there own and how many houses nether mind commercial premises have we been to when the property has not seen an electrician for over twenty years? answer is plenty. the insurance companies could be the key to all this.
what they need to do is to put a clause in the policy (probably already is) and emphasise to the insured party that the policy will be null and void without a full periodic being carried out at the inspectors recommended intervals and all remedial works that are needed are carried out after with a minor works certs. the big thing is the insurance companies need to be made aware that there is more than one scheme where people can be registered and still be competent. yes this would not solve all the issues out there with properties etc and not all of them would carry out the recommendation but if we can get it across to the landlords who probably have their gas checked every year surely they could be persuaded to have the electrics done in the times recommended.
the iet is big enough to throw their weight behind this one and make it happen. too often it`s too easy to sit back and do nothing but take the £150 a year membership or whatever it is these days and produce the regs.
Phil
The fire industry in all its various parts from systems, to portables to consulting and risk assessment has seen this sort of thing for a while now.
Essentially, the law is enforced by the Regulatory Reform (Fire Safety) Order, and by supporting Acts, such as building regs, BS9999, and various other bits n pieces.
What it essentially all comes down to is that the onus is on what's known as the "Responsible Person" to ensure (1) that a Fire Risk Assessment is carried out, and (2) that adequate provisions are in place for the depletion of risk from fire in a premises.
Now, for my money, a much under used part of these acts are that electrical systems are a major source of ignition, and hence a potential risk to fire safety.
Any fire risk assessor has it in his or her power to identify, and insist upon a Periodic Inspection of the electrical system, as part of the fire action plan. It isn't noted nearly enough in my opinion.
The point is that for any Landlord, and any HMO, a Fire Risk Assessment is a legal obligation. I think risk assessors who fail to mention electrical system integrity - up to date PIRs, PAT testing for appliances, are in neglect, and that these tests should all be mandatory at change of tenancy, or annually, given the nature of many tenants in particularly short term occupancy HMOs. Not just a Gas safety check.
IMO, this should apply to any tenanted property and not just an HMO. You can bet your bottom dollar that insurance assessors would be on it more, were it law.
Fire Risk Assessment, while a legal obligation in many cases, sadly isn't policed as much as it should be - Fire Officers have the power to push prosecution for failures, but don't have enough in the way of legs. Insurance companies, too often, take the view that it is only an issue once a claim is made, and then largely will simply refuse to pay out, leaving victims to bring the prosecutions.
It's one of the reasons that we started offering PIRs as well as PAT testing - because we do a large number of Fire Risk assessments, and I reckon in the last 200 or so carried out, only about 20% have had current test records for their electrical systems - domestic and commercial.
Sadly, most of them think they can get away with it, and they can, generally, until something happens. Until then, they seem to think that a few extinguishers and a smoke detector or two will do the job.
IMO, properties other than purely one family domestic owned, should be required to display somewhere prominently, a current PIR, PAT test register, Fire Risk Assessment, Gas Safety Cert, Insurance cert, and building regs compliance cert, before being allowed to operate in a capacity of what, essentially is business - whether that be a Landlord letting a single dwelling or HMO, commercial premises, or any place of entertainment, public access, or residence not owned by the occupier.
Draconain? Not really - but it would be the single easiest way (especially if all other certs had to be produce prior to insurance cert being issued) to stamp out cowboys, negligence, and a lot of shady practice.
