Discuss THWN-2 defect, nylon sheath delam in the USA Electrical Forum area at ElectriciansForums.net
No, the cable is brand new and delams like that right after it comes off the spool. 300mcm aluminum.Has the sheath split?
More words to meet forum requirement.
I have seen wires pulled into conduit that actually peel the plastic wrap back like that. You mentioned that it come off the reel like that so the supplier would probably give you different wire but then you would have to pull it out and replace it. I wouldn’t think that it would be worth the effort to repull the wiring. I have actually seen worse. Good luck and welcome to the forum.What would cause the nylon sheath to delaminate from the
This is brand new cable from Zhejiang permanent cable in China 22 days after manufacture and 2 days after delivery. Normally I wouldnt go to China for this product but the project location is in Cambodia and geographically much closer.This might be one for one of the USA based folks such as @Megawatt to comment on as that sort of cable is not really seen in the UK, etc.
However the most obvious reason is faulty manufacturing. Have you contacted the supplier or manufacturer?
Even if it is years old it should spool out OK (unless subject to abuse such as storage in extreme temperatures, or near solvents, etc).
This is being hung overhead and is put up resting on pole as it is rolled out and then secured with purpose built hardware.I have seen wires pulled into conduit that actually peel the plastic wrap back like that. You mentioned that it come off the reel like that so the supplier would probably give you different wire but then you would have to pull it out and replace it. I wouldn’t think that it would be worth the effort to repull the wiring. I have actually seen worse. Good luck and welcome to the forum.
Another picThis is being hung overhead and is put up resting on pole as it is rolled out and then secured with purpose built hardware.
Yes, the labor and effort involved in replacement is high. Thanks
It looks like the supplier had it actually stored outside. I guess that is what it looked like before you installed it.Another pic
No, that is at our location. Manufacturer produced and shipped new cable, they said. That is at the end of spool and just wanted to show how some was delaminating even before it came of the roll.It looks like the supplier had it actually stored outside. I guess that is what it looked like before you installed it.
Yes, according to Eland Cables:No, that is at our location. Manufacturer produced and shipped new cable, they said. That is at the end of spool and just wanted to show how some was delaminating even before it came of the roll.
My understanding is that THWN-2 is outdoor approved for exposed runs. Is this correct?
It would be worth talking to Intertek. They have an office in Cambodia, though their cable experts/labs may be somewhere else in the world!If anyone can offer more insight into why it is defective or could point me to an independent testing lab or other manufacturer for a written assessment it would be appreciated.
We called Intertek in Cambodia. They said they dont do that testing here and could offer no other information on who else to call. Maybe I will try their main number.It would be worth talking to Intertek. They have an office in Cambodia, though their cable experts/labs may be somewhere else in the world!
Contact Information for Cambodia
www.intertek.com
Sorry to hear you didn't get much help. I have used Intertek in the UK and Europe for compliance testing and found them helpful and reasonable value. The difficulty is finding the right people to talk to, and I suspect it will take both effort and time which you might not have.We called Intertek in Cambodia. They said they dont do that testing here and could offer no other information on who else to call. Maybe I will try their main number.
I have also reached out to UL with no response and sent several emails to Neetrac and Eland in UK with no responses yet after 4-5 days.
All ideas appreciated.
Yes THWN is approved for outdoor and wet locations.No, that is at our location. Manufacturer produced and shipped new cable, they said. That is at the end of spool and just wanted to show how some was delaminating even before it came of the roll.
Reply to THWN-2 defect, nylon sheath delam in the USA Electrical Forum area at ElectriciansForums.net
