Discuss THWN-2 defect, nylon sheath delam in the USA Electrical Forum area at ElectriciansForums.net
TMarkee
What would cause the nylon sheath to delaminate from the
This might be one for one of the USA based folks such as @Megawatt to comment on as that sort of cable is not really seen in the UK, etc.
However the most obvious reason is faulty manufacturing. Have you contacted the supplier or manufacturer?
Even if it is years old it should spool out OK (unless subject to abuse such as storage in extreme temperatures, or near solvents, etc).
Cant be sure but could it be that the outer layer of the cable has degraded because of UV from sunlight.
otherwise it could just be a reel of faulty cable.
I have seen wires pulled into conduit that actually peel the plastic wrap back like that. You mentioned that it come off the reel like that so the supplier would probably give you different wire but then you would have to pull it out and replace it. I wouldn’t think that it would be worth the effort to repull the wiring. I have actually seen worse. Good luck and welcome to the forum.
This is brand new cable from Zhejiang permanent cable in China 22 days after manufacture and 2 days after delivery. Normally I wouldnt go to China for this product but the project location is in Cambodia and geographically much closer.
I immediately contacted them and they are making excuses as to why it is not their fault. Yes we are in a dispute. We have 400 m x 2 spools already pulled and 98% delaminated.
If anyone can offer more insight into why it is defective or could point me to an independent testing lab or other manufacturer for a written assessment it would be appreciated.
This is being hung overhead and is put up resting on pole as it is rolled out and then secured with purpose built hardware.
Yes, the labor and effort involved in replacement is high. Thanks
It looks like the supplier had it actually stored outside. I guess that is what it looked like before you installed it.
No, that is at our location. Manufacturer produced and shipped new cable, they said. That is at the end of spool and just wanted to show how some was delaminating even before it came of the roll.
My understanding is that THWN-2 is outdoor approved for exposed runs. Is this correct?
Yes, according to Eland Cables:
It would be worth talking to Intertek. They have an office in Cambodia, though their cable experts/labs may be somewhere else in the world!
We called Intertek in Cambodia. They said they dont do that testing here and could offer no other information on who else to call. Maybe I will try their main number.
I have also reached out to UL with no response and sent several emails to Neetrac and Eland in UK with no responses yet after 4-5 days.
All ideas appreciated.
Sorry to hear you didn't get much help. I have used Intertek in the UK and Europe for compliance testing and found them helpful and reasonable value. The difficulty is finding the right people to talk to, and I suspect it will take both effort and time which you might not have. 🤔
Try BASEC
Yes THWN is approved for outdoor and wet locations.
Reply to THWN-2 defect, nylon sheath delam in the USA Electrical Forum area at ElectriciansForums.net
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
In preparation for an EVSE installation, I am running the supply cable from the main CU, via catenary, to a new CU in my garage. The cable is 6mm...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician State Laws for Electrics and Electricals may differ on a state-by-state basis. American questions and answers can be found in our UK electrical forum.
