Thank you very much. I spoke to my employer last week, she said it would only become an issue if the cable was frayed, exactly what you kindly explained. She said that they have an ‘electric shock’ system in the house. But as another gentleman in this forum said, I would have to rely on this system to work properly. Hence I would ideally like to get a RCD adapter as a back up plan, but I feel worried to bring the subject up for a second time with my employer. I don’t want them to get funny with me. That’s why I am trying to educate myself, so hopefully my anxiety will dissipate. So the cable shouldn’t give me a shock, unless the cable is damaged with colourful wires showing. Hope I am understanding you correctly, I am a complete novice. How could the actual steamer give me a shock? I do appreciate your help.I was saying an electric cable lying in water is not of itself unsafe. Think of the many many cables under wet ground all around the world supplying houses with electricity!
I wanted to put the case that a cable in water (suitable for it) is not a bad thing, or something to be frightened of, but if the cable gets damaged that becomes a different matter.
I had two mains powered pond pumps, and their long mains cables lived happily under water with the fish for many years.
Your Shark flexible cable has an outer covering of plastic insulation, then inside that are the two or three wires, each of which is covered with their own insulation of different colour.
If your Shark flex were to get so damaged or cut/abraded through the outer insulation that you could see coloured wires inside, that is a potential hazard and you must stop using it. You still wouldn't get a shock, but there's now a greater risk.
If further damage should occur there could be a bare live wire, which could give you a shock if you touched it.
However if the RCD plug previously discussed was in use in this situation, it would disconnect the power before you got a serious shock.
Just as an example - I've seen an upright vacuum cleaner that had sucked up it's own flex, and on rescuing the wire, the outer covering of the cable had been rubbed away and you could see the insulated wires inside. The vacuum had to be taken out of service and a new flex fitted. But still nobody would have got a shock from it.
What you've been told is true. I wonder if the worry stems from thinking that having the Shark cable in water is itself "mixing water and electricity", which it isn't (until the cable becomes damaged or broken, at which time it is!)
I would say that the aim of the people who designed and manufactured the Shark cleaner would have been to make sure electricity and water never mixed in their product, but they would say responsibility for maintaining the cable in good condition lies with the user.
I'll stop being an Engineer, and I must apologise for the verbose replies.
At the end of the day if you are still fearful of the very wet floors with the Shark steamer, you really should make that clear to your employer.
