Welcome to the forum.
If you want recessed downlights then you will need a space behind the ceiling, but this could just be the void behind an existing plasterboard/joist ceiling.
You could also go for surface mounted fittings. But bear in mind cables will need to be routed to them.
Thank you which it can be done on a normal ceiling wall?
Downlights are recessed so not suitable for a ceiling made of cement. Surface lights are the option here, but then you’ll need cables going to the light(s). Those cables would be on the surface, unless you fancy cutting chases into the cement.
Singapore
Singapore
Do I need false ceiling to mount spotlights?
nishay,
Jukv96,
