I really don't know where the confusion is, if the tenant changes that is a change of occupancy? How can you interpretant any other way?
What the regulations say:​
Private landlords must ensure every electrical installation in their residential premises is inspected and tested at intervals of no more than 5 years by a qualified and competent person.
  • supply a copy of the most recent report to any new tenant of the specified tenancy to which the report relates before that tenant occupies those premises; and any prospective tenant within 28 days of receiving a request in writing for it from that prospective tenant
Just went through this: Guide for landlords: electrical safety standards in the private rented sector and I can't find it either, I am obviously not current, retired ten years ago, sorry for any confusion, mostly mine.🥴
Notwithstanding, IMO it's a good idea to carry out an inspection on the change of tenancy, as I said above who knows what a tenant has done to the installation during their tenancy.
The GN3 I have (17th edition, 2015) in section 3.2 says inspection & testing should be considered in a number of circumstances, including (in sub-section (c)), "on a change of occupancy". This pre-dates the 2020 private rental sector legislation, and I think at the time, few landlords actually did any testing & inspection at all.
Now that it is mandated every 5 years, at least for the 2 letting agents I do work for, the inspection & testing is generally only done every 5 years (2025 is going to be busy, if I'm still working then).
.Now that it is mandated every 5 years, at least for the 2 letting agents I do work for, the inspection & testing is generally only done every 5 years (2025 is going to be busy, if I'm still working then).
Probably going to be expensive in 2025. Smart letting agents might want to get the ball rolling next year.
I always say EICR, or at least a “mini” version between tenants for two reasons.
1. You don’t know what DIY Dave did during the last 6 months.
2. It’s in my best interest as an electrician to find work.
I knew I had read it somewhere, but it is the Housing (Scotland) ACT 2014.
“19ADuty to ensure regular electrical safety inspections​
(1)The landlord must ensure that regular inspections are carried out for the purpose of identifying any work which—
(a)relates to installations for the supply of electricity and electrical fixtures, fittings and appliances, and
(b)is necessary to ensure that the house meets the repairing standard.
(2)The duty in subsection (1) is complied with if—
(a)an inspection has been carried out before the tenancy starts (but not earlier than 5 years before the start of the tenancy), and
(b)inspections are carried out during the tenancy at such intervals to ensure that there is a period of no more than 5 years between each inspection.
Full text here: Housing (Scotland) Act 2014 - https://www.legislation.gov.uk/asp/2014/14/section/23
I'm not sure if I'm reading this the same way was you are, but 1- this only applies in Scotland. 2 - the inspection only has to be done before the tenancy starts, which can be up to five years before the tenancy starts. So every five years, regardless of change of tenancy.
As Loz says, the paragraph states that an inspection must have been carried out before the tenancy starts, but no longer than 5 years before. If there is already a current (ie less than 5 year old) cert in place then there is no requirement to do another one.
So every 5 years.
