Adam_92
Trainee
Has anyone come across click accessories spurs burning out?
it seems to only be happening with the CNS200 Trend uk Steibel eltron heaters
Fuse is still fine just the spur itself is burning out had so many of these
Thanks in advance
Adam
Modern day accessories regardless of brand are prone to failure from loads such as heaters I have replaced countless. Wherever possible avoid FCUs and fit double pole switches but these are not infallible. Fit an FCU to a sufficiently rated heater, give it five minutes and it will be getting warm.
This looks the same as yours.
Thanks for the advice will change to DP switches But why is this happening with heaters and not waterheaters really strange
Only change to DP switches if protection is not affected. Water heaters tend to cycle through the thermostat so are not heating for long durations. Heaters tend to be running all the time, my pic was a 3kw ceiling heater running all the time.
