Hi guys. I will start by apologizing for the elementary question. I'm sure you get them often.
The chandelier is in a hallway controlled by a switch. There is another light source in that same hallway but separately controlled by a pull chain bulb (still works). (in case it is important). Well, I tried to turn on my hallway light and nothing happened. Checked the breakers and everything seemed fine on that front. I have a kaiweets vt500 voltage tester pen and seems like both chandelier (tested via the e26 bulb size opening where you put the bulb in) and the switch area connections are reading live voltage. What are other reasons for the chandelier not working? if it has a live connection where the bulbs are, and where the switch is, why wouldn't it turn on?
I hope this makes sense.
Thank you for your time.
