Discuss RCBO or not? in the UK Electrical Forum area at ElectriciansForums.net
Folks.
I need to install a defib unit outside on a wall.
Does this require an RCBO or not, just wondering as the unit has a small heater within and should it trip out for any reason other than under fault conditions (it is in a dampish environment, a harbour) it will get damp.
So MCB or RCBO.
Many thanks
AJ.
Just a thought and probably not relevant but there are some exceptions in the regs regarding medical equipment,
cant remember exactly what they are but on occasions protection may be omitted or reduced to ensure the device remains functional.
or am I thinking of lifting magnets? its been a long day but there are a few things to look up in the bible if any one is interested.
Reply to RCBO or not? in the UK Electrical Forum area at ElectriciansForums.net
Just a thought guys in terms of RCBO’s and supplementary bonding. Obviously supplementary bonding isn’t required as long as a 17th / 18th...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
So I have just swapped over to using fusebox as my go to brand for CUs and I noticed they stock a 25A RCBO…mmmmmm do any of you use these a great...
