colink
Northern Ireland
Hi
My electrical background is Auto Electrics from decades ago - 230v electiics experience is very mucch DIY.
Willis type 3kw heater. Currently switched with a DPST Manual switch.
I am hopping to add a relay in parallel with the manual switch. Relay will be switched from a SONOF / eWeLink smart switch with 230v AC output.
Just double checking if there is anything I have missed regarding the spec / suitability of this DPDT relay?
I am OK with working out what coonnections to use and not use.
If any isues with this relay please sugest an alternative.
JQX-12F-2Z AC 220V Coil 30A Relay DPDT 2NO 2NC 8 Pin General Purpose High Power Relay​
https://www.amazon.co.uk/Xiatiaosan...lpcontext&ref_=fplfs&smid=A39XV54ATO7F2U&th=1
Hi
Hi
I would use a din rail dp contactor in an enclosure.
Yes - that looks like th ecorrect relay.
I am not mounting in the consumer unit but below the hot press where the hot tank is. I presume this DIN mount will allow me to mount it to the hot press structure - ??
As this will be passing 3kw, is the DIN rail important for heat dispersion?
https://www.screwfix.com/p/schneide...c-section-din-rail-35mm-x-7-5mm-x-214mm/491hv
Don't leave that loose. Mount it in a DIN rail enclosure. Bear in mind the hot press could also be moist.
Reactions: mainline and colink
No issue. Just checking in case I missed something. Better safe than sorry with 230v an 3kw!
Eg @Risteard warned me mount the DIN rail option and not leave it loose.
Northern Ireland
Is this relay suitable for 3kw Willis Heater
colink,
colink,
