Jan 27, 2019
54
Wick
Hi everyone
Is it permissable to connect 2 immersion heaters to one RCBO and supply cable?
I'm installing a water cylinder (which has 2 immersions) in a new utility room, which used to be a kitchen.
I want to repurpose the old cooker supply cable which is 10mm. If it's legal, I want to feed both immersions vis seperate DP switches, but they will share the same RCBO in the consumer unit.
In short, is there any way I can use this cable to power 2 immersions? Pulling another cable via the same route as the original isn't possible - I'd have to run it along the outside of the house. If I have to I will, but it's not ideal.
Thanks for any advice.
you could put a small consumer unit on the end of the 10mm
a 4 way garage board would be ideal.
Most HW cylinders that are heated solely by electricity have two immersions, but only one is normally used at a time.
Thanks for that - I was thinking along those lines.
Much appreciated
Thats true - but do the regs allow then to be supplied by the same cable/breaker?
Also, although they're generally only used one at s time, they COULD both be active if the cylinder is cold, although the top one would stat itself off fairly quickly.
Controllers that are intended to control twin immersion cylinders only allow one to be powered at a time.
Wick
Shared immersion heater circuit
DIY Electrical Advice
Philip Saunders,
brianmoooore,
