I wanted to convert 5 halogen down lights with new LED fittings and got these from TLC https://www.tlc-direct.co.uk/Products/CLH2CSPW.htm together with a Varilight V-COM as per recommendations.
Installed it all but the LEDs would not light up - even though I programmed the switch with 3 ON/OFF presses etc etc etc.
I then removed one LED and replaced it with one old halogen fitting. The dimmer controlled that one halogen fine but none of the LEDs.
Any suggestions on what I should try next?
