Status
Not open for further replies.
When and where has a fuse been wrapped in paper and what does that have to do with the overload protection of circuits?
You are making less and less sense.
What photo of an X-ray?
If you want us to look at a picture the please post it up so we can see it.
And to answer your earlier point yes you would need to remove the fuse from a plug in order to get the best possible X-ray image.
They had to clean residue off of the fuse before X-raying it, then they added a photo of the X-ray into the report that was available online.
The fuse element was still intact.
Hang on a minute!
Does this mean your 'friends in high places' have been removing evidence from the internet?
Not to worry, I imagine the Police will have copies.
It is Friday, I have had enough for one week.
Have a nice weekend.
So someone wrapped an intact fuse with foil and it caused a fire due to a faulty appliance ? Is that supposed to be a surprising thing to happen ?
Look at the photos of Grenfell.
The fire originated in a Hotpoint fridge-freezer in flat 16 on the fourth floor. A faulty electrical connection, possibly a loose wire, within the appliance is believed to be the cause.
There was initial confusion and speculation about consumer units (fuse boxes) being a potential cause, stemming from a change in how the London Fire Brigade reported these types of fires.
Actual Cause:
Investigations revealed that the fire started due to an electrical fault in a fridge-freezer located in a fourth-floor flat, specifically a poorly crimped wire connection within the fridge's wiring
Status
