- Jun 16, 2025
- 83
- 7
- 1,193
- United Kingdom
- Retired Electrician
How?Yes, of course it can, and the larger that overload is the shorter it's duration will be as the overload protection operates.
How can a ring final circuit be exposed to 'a large overload of a short duration'?
You could have timed heaters plugged into the socket outlets in different rooms, all on the ring final set to come on at the same time.You mean that you would have to switch on the entire circuit, with everything plugged in and switched on ready to go.
Does this happen often?
Or does it tend to coincide with periods of time when you have nothing useful to do?
The evidence suggests that you are correct about the temperature being the key, but experience has demonstrated that it will be the join between the line pin of the 13amp plug and the socket outlet where the point of ignition will be found.
If you choose a 32amp BS EN circuit breaker it should therefore be matched with a 4.0mm conductor ring final circuit and earthed metal-clad socket fronts.
Look at the photos of Grenfell.
I’ll agree with thatI'm not an expert
x ray it for what ?but as far as I know; there shouldn't be any need to take a three pin plug apart before you can X-ray the fuse.
It must have been open circuit otherwise why was it wrapped in foil.To see whether the fuse element was still intact.
