- Jun 16, 2025
- 83
- 7
- 1,193
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Retired Electrician
How?Yes, of course it can, and the larger that overload is the shorter it's duration will be as the overload protection operates.
How can a ring final circuit be exposed to 'a large overload of a short duration'?
You could have timed heaters plugged into the socket outlets in different rooms, all on the ring final set to come on at the same time.You mean that you would have to switch on the entire circuit, with everything plugged in and switched on ready to go.
Does this happen often?
Or does it tend to coincide with periods of time when you have nothing useful to do?
