Her is the final video. I have a roll of audio cable, it is 0.5-1mm diameter copper which should be fine for the 3W led, but I just used both veins for safe measure.
No, No, No.
The insulation around audio cable is not rated for 230V (or 240V as it more commonly is in the UK) even if it is the right CSA.
This is an accident waiting to happen.
You need to find the break in the original wire and replace it with proper mains cable or re-terminate it if the break is at an accessory.
Have you checked the cable in the loft? Could it have been nibbled by vermin?
I have a light that trips the 5A fuse. It trips it regardless if there is bulb in it. And regardless of which neutral wire switch is on (it has two). And it did trip the fuse once after I disconnected the fitting (to eliminate it). Then I hooked a tester to it and for some reason it has stopped tripping it. Fitting shows full resistance 1 but if I connect live and neutral to the ohmmeter with fuse on (switch off), the Ohms fluctuate. After switching the fuse off, the fluctuations gradually not in frequency but in amplitude go down. It is about 4s cycle.
Update: The light in the bedroom next to it, hooked to the same fuse stays firmly on 1. Then going back to the iffy one, fluctuates again. That is with live wire live and neutral disconnected at switch.
First question: Are you an electrician?
2nd Q: Why are you testing continuity between Live and Neutral?
Go and get an electrician before you blow something/yourself up.
Dont try to fix electrix via Youtube tuition
