You could have timed heaters plugged into the socket outlets in different rooms, all on the ring final set to come on at the same time.You mean that you would have to switch on the entire circuit, with everything plugged in and switched on ready to go.
Does this happen often?
Or does it tend to coincide with periods of time when you have nothing useful to do?
I know of a few rental properties that have them, they replaced a 12kw electric central heating system that caused a fire in the one property.
