FloridaGuy
I needed to wire a lamp circuit on a dimmer to a flush mount outlet box so I could access a hidden LED strip light by loosening an entire panel, unplugging the LED driver, and removing the panel for service etc. I got the job done and tested the outlet with a Klein outlet tester. I was surprised to see 108 v. I was concerned that I had a poor neutral connection and checked the wiring all the way to the outlet fixture with my multimeter and had 118 v. I checked the outlet with the multimeter and got 118 v, but the Klein still gave 108v. The dimmer is a forward-phase type and was full on. I am speculating that, even full on, the dimmer was "trimming" the sine wave slightly causing the Klein to show 108 v. But the fact that the multimeter showed 118 v indicates that these two instruments measure AC voltage differently. I should add that both instruments show 118 v when I test a regular outlet on the same breaker. Is my specuation correct? Thanks for your help!
