Aug 29, 2025
UK
First off diy'er so be nice. Just wondering if anyone has any experience with Quinetic switches / receivers? I have an outside security light, installed about three years ago, which is switched on and off via a 2 gang Quinetic switch at my back door. The receiver is fed via an FCU from the lighting ring and situated in a wiska box directly above the light. (There doesn't appear to be any water ingress into the box) When i press one of the switches the RCD in my CU trips, none of the individual mcb's. I thought at first it was just a coincidence but it happens every time I press the switch. Been doing it for three days and does it every time I press the switch. I've switched the receiver off via the fcu it's powered by, still does it. I've disconnected the receiver completely (don't shout, by this point I was losing the plot) still does it. The other gang of the switch which is doing a different receiver works perfectly. If i reconnect the circuit and pair it with a different switch it works fine. I've got someone coming to look but in the meantime my question is how can a wireless switch that effectively isn't connected to anything trip an RCD? Am i missing something blatantly obvious??
There is no electrical connection to the switch at all, so issue must be with receiver.
You said no water ingress into the box, but what about the light fitting?
Was the receiver completely disconnected? Input and output? Or just unpaired from the switch?
check your input and output connections are right and there’s no stray flex wires hanging out the terminals.
It may be as simple as moisture got into the receiver… maybe just replace it?
Thanks for the reply. That was my first thought but here's the thing. I completely disconnected the feed to the receiver and light fitting, basically leaving the spur with just an input. No physical connection from the receiver to the supply, still does it. (Just checked again) I was also thinking water at first because it's worked perfectly the last three years, but how can a wireless switch that's not connected to anything trip an RCD? Like I said with everything reconnected and using a different switch it all works perfectly so you would think switch but how??
So the receiver isn’t powered up at all?
It hasn’t somehow got paired with the other receiver, and that’s causing a problem?
Update. I've completely removed both receivers. There is now no Quinetic receivers connected anywhere in the house (see pic). As you can see from the video...still doing it. I swear if I didn't see it with my own eyes I wouldn't believe it. I might have to contact Quinetic direct and see if they can shed any light.
View attachment Trip.mp4
Maybe another receiver somewhere connected to a faulty circuit/light fitting, paired with that switch?
Reactions: mainline
If it does it at a decent distance from the CU then you must have another receiver somewhere.
You could try turning off other circuits to narrow it down, but it may be on the same lighting circuit as the others.
Reactions: DefyG
Definitely no other receivers in the house. We've been in from new and I know everything that's been installed since. As soon as I've got some daylight i'm going to try and narrow it down to an individual mcb and go from there. Thanks for the responses everyone. I'll post how I get on.
Strange one
Must be something else using same frequency as the quinect.
Any other smart devices? Thermostat? Remote controlled socket adaptors?
How have you left the disconnected wires? Safely in connector block, with no chance of touching anything else?
Just 'Googled' it as at a loss - suggestions;
1. Overly sensitive RCD (RF Effect of switch causing trip mechanism to activate)
2. RF of switch causing 'other' equipment with high earth leakage to activate RCD.
Odd that the other switch doesn't cause it to trip.
Clutching at straws, are the lights already quinetic configured (ie integral receiver)?
Have you reconnected switch and lighting circuit(s) to confirm that works ok without tripping the RCD (ie bypassing the receiver)?
Implies something amiss with the original switch set up?
Is the switch possibly paired with more than one receiver?
Sometimes clutching at straws reveals the answer….
There was evidence that some smart meter communications could trip an rcd, so rf interference wouldn’t be such a daft idea.
Op, is there a range that the switch doesn’t trip the rcd? Ie, outside the house… bottom of the garden?
Reactions: DPG and DefyG
There is a big difference between a mobile device transmission compared to a kinetic one.
The kinetic one is very low for a short time.
One way to find out would be to cover the CU with foil and go about 10 ft away from it and see if it trips.
So I nearly didn't post this because i'm a bit embarrassed but thought you'd all want to know the answer. Started off by isolating which circuit was causing the problem and by a process of elimination got it down to one doing the downstairs sockets, not a lighting circuit. Unplugged everything in the house and still did it. So I thought I would give each socket a little look and see if there was anything obvious. Worked all the way around the ground floor and found nothing and lastly checked the conservatory. When it was put in I got the builders to put an external socket on the outside so I went to check that one. All ok but there was an armoured coming out of the socket which I was convinced went around the side of the house and up to the security lights at the side (one of the receivers i'd removed) Turns out before it gets there it's terminated in another Wiska box hidden behind some shrubbery. Then the penny dropped. Originally there were some ground level floods lighting the path, long since buried in foliage. Disconnected the lights being fed by the receiver and nothing, plugged them back in one by one and when i plugged the second one in it tripped. Unplugged it again and nothing. So I put everything back in as it was originally, minus the one floodlight, and all good. So much for knowing your own property. Basically all down to a water filled floodlight buried in a bush. How stupid do I feel? The only thing I can't understand is why the fob worked but the switch caused an issue? Anyway thanks to everyone who responded, much appreciated.
Well done for finding the problem... We can all sleep soundly again.
UK
Quinetic switch anomaly
DIY Electrical Advice
Tags Tags
switch
sparky2475,
littlespark,
