G
Grim001
I am a novice at wiring but learn quickly but this has me stumped. I am wiring my garage with over heads led lights. I wanted to run 12/3 wire in one direction and not have it circle back around to breaker panel. to save money and work since it is 60 feet long. My panel is at one end of the garage and my door with light switch is at the other end . I have 10 (2 bulbs each) led lights (no ballast) and at the end of the wire chain is a light switch. I found on a forum a way to do it and followed it.
Here is the way I wired it. I have the neutral wire going from the panel to each light fixture via daisy chained but it stops at last light, does not connect to the switch.. The black wire is starting at the first light (closet to the panel) and daisy chained all the way to the switch (bottom). The red wire starts at the panel and goes straight to the switch(top).
I have 8 of the lights hooked up currently, There are two different styles of lights, its what I had on hand! The first five are hardwired and the rest have a electrical plug on then so I have a box with an electrical plug wired in. The five hardwired one are working, on 65V, but the ones with the electrical plug don't, , none of them. I plug a different device in one of the electrical plugs and it didn't come on either. That is when I put a meter on it and got 65V.
I read that is is a neutral problem but I don't know how to test to find where the issue is with my wiring configuration.
I would definitely get an electrician to look at this for you as it sounds like something is wired totally wrong here.
Are you in the UK?
Usual way to wire lights is loop in, loop out of each light fitting to the last light.
Drop a switch wire from a desired light and switch the LINE conductor to supply all desired fittings.
This also would need careful design to make sure current carrying capacities and voltage drop is taken into account and MCB / Rcbo is correct size and it has been tested and inspected.
Are you in the UK?
They are not from the UK
Most likely it is a Neutral problem with the symptoms you describe.
The obvious thing is to re-check all of your connections. Start at the point where the lights stop working. So last working light and first non working light since that is likely the 2 places you might have a loose connection.
