Hi, not sure if I am over thing this but thought it best to ask.
I bought a humidity controller for a pet enclosure. It has a mains plug and to outlets. The mains plug is a two pin euro and the two outlets are none polarised schuko sockets (although the pin holes are labled N and L) so the schuko plug can be plugged in either way. The package came with three euro to uk adaptors.
The two outlets are close together and while the adaptors fit ok when I plug in the two uk plugs they push against each other causing them to not sit entirely flush.
The equipment I plug into these are a usb power adaptor and a 240v ac to 24v dc psu. It's been working fine but I thought I'd replace the uk plug on the psu with a schuko plug and also get a eu usb power adaptor from Amazon Germany so they plug in and don't interfere with each other.
My question is is this ok to do this? Obviously UK wiring circuits are designed for a polarised plug that fits one way. Are there any hazards to using non polarised plugs in this set up?
Also as the main plug on the humidity controller is two pin - there is no earth. My psu has live,neutral and earth wires.
I know people from europe holiday here and plug their non polarised items in via adaptors so is my setup basically the same thing, or am I missing something?
You need to check if any of the equipment is Class I or Class II.
Class I will need an earth wire
Class II is known as double insulated and will have a “square within a square” symbol and does not require an earth wire.
Thanks littlespark. My PSU is class 1. The usb chanrger I ordered is class 2 so I have also ordered a class 2 psu from Germany and a euro to uk plug adaptor for the humidity controller that is fused protected unlike the cheap adaptors sent with the system.
