littlespark
Staff member
Supporter
Patron
See what I did there…..
Although a technically advanced city, some of their infrastructure could be looked at.
The underground subway is immaculate. Trains are quiet, not crowded and punctual.
No gangs of yobs… there’s a culture of consideration and respect across the entire city.
The traffic is a bit of a nightmare… I’m glad I’m not driving. Pedestrian crossings are timed. There is a button for crossing which allows a longer cross time for disabled… but for able bodied…. You just wait for the lights.
Busy crossings have a numbered countdown on green and red to either let you know how long you’ll be waiting before crossing, or to let you know how long you’ve got to get across…. Which could be up to 8 lanes on some roads.
A quick look at some of the services… this is a common gas meter position… some are chromed pipes. But completely straight and even. The gas engineers must be well trained…..
Then the electricians came along…..
Food and drink.
It all started so well… lots of salad, veg, lean meat. Sushi, rice and seaweed…. Berry smoothies designed to cleanse the body…
And not a fizzy coke or beer to be seen.
Day 2, and we found a Macdonalds.
The maccies above is in the COEX Mall in Gamgnam district… and even though our hotel is also in Gangnam, it was still a 30 minute, 4 train changes on the underground to get there.
The COEX is situated at the Korean World Trade Centre, and also the home of this strange piece of artistic structure…..
Massive photo op for locals and tourists… there’s a button that plays the damn song so people can have a little dance…..
Yes we did take a photo in front of it. No, I wasn’t dancing and No, I’m not uploading the photo.
In the mall, I also found a Lego shop. Happy me.
I’m getting a little seasick from all the underground train journeys…. So maybe tomorrow is a walk around the neighbourhood day.
This is the view from our 13th floor hotel window… looking out to the North of Seoul.
Zoom in at the arrow, and you’ll see the Namsang Tower, where we visited today. A 2 train run out on the underground, then the worst bus experience up the hill to the tower.
From the bottom of the tower looking up….
Didn’t go right up to the observation deck at the top, but from the bus stop…
Zoom in between the trees, and you can see the highest building in Seoul….the Lotte Tower.
Which we will be visiting another day….
Another shopping mall, an aquarium…. (Another Lego shop) and, if time permits…. A high open air walkway between the two high points… !
I think I’ve found my new profile picture….
Back street caricature artist in-between a street food vendor and a Gatcha machine shop… ( that’s an unmanned shop full of vending machines, where the products inside are blind bags. You don’t know what you’re getting)
It took the artist less than 5 minutes to draw all 4 of us.
Today we visited Gyeongbokgang Palace in the rain. A spot of history in the ultra modern city.
Lots of open space and buildings with the inverted curved roofs.
Even the electric box had a little inverted curved roof
Speaking of electric… another example of the fine infrastructure running over our heads down every side street.
Looks like 3 phase into 3 separate transform area… then just slung out between all the buildings. There’s power, telecom and fibre all running off the same poles.
Slight distraction from the palace… where many of the ceilings were painted…. Just an example above one of the entry gates…
Heading home now.
Will update when I get a chance.
Something you’ve all been waiting for……
The rest of the electric pics!!!! Woooooo!
Not been the weather for it
Just back home.... So we've got unpacking, washing, all the usual post holiday stuff before i can go through my photos again.
Ok…. So I showed you a couple of the spaghetti string supply cables hanging off poles…
South Korea uses the same Type C and Type F plugs and sockets as Europe, Russia etc, 230v and 60Hz…. So we only needed a couple of adaptors for our things to work.
The hotel we were in, however, must have thought it was a good idea to use a multi fit socket… where our regular Uk plugs would also fit.
They were so worn out, anything like a hair dryer would rattle on the socket and eventually fall out. The pins would be hot to touch as well.
Not a good start.
The electric meters, like the gas meters were mostly on the outside of buildings, but not in any protective enclosure. Seemed rugged enough though.
Of the consumer units I’d seen, they were recessed into the wall, plastic cover and lid… and had RCD protection on the final circuits.
One particular cafe we were in used something similar to “knob and tube” used in early USA and Japan installations.
You can see the inner cores of the flex feeding the pendant connected to the two conductors between the porcelain insulators.
This wasn’t high up in the ceiling. I could reach it if I stood on a chair . (I didn’t)
A lot of the side street shopping areas had food stalls running up the middle….cooking by gas, but their lights, signage and POS terminals were supplied by one extension lead across the road, then piggy backed, extension lead to extension lead, supplying up to 6 vendors… and no sign of any IP rated equipment… was the same plug and sockets used there as indoors.
There is CCTV everwhere…. But that might just be a city thing. And most small shops and cafes we visited was using ADT branded…. Must be cheap there.
The mini trunking must have been fitted by a blind man though…. And this wasn’t the worst. At least this had lid.
Fallen behind a bit with doggy worries.
Korean exports.
Starting with the cars. Kia is one of the big manufacturers here… we have a picanto at home, but in korea it’s known as a “Kia morning” How cute.
Kia also make busses here…
Hyundai is another big manufacturer… maybe the biggest. Cars, pickups, vans… even the underground trains are made by Hyundai…. And so is the escalators, elevators and ticket barriers in the stations… All Hyundai.
Mobile phones. Even though there’s a good few Apple stores, Samsung are the big players.. also making the big building sized billboard screens.
LG… who I didn’t know were Korean, and only made TVs and kitchen appliances, have their hands in everything. They are the electricity network supplier, one of the mobile networks and have their name on drainage manhole covers.
The biggest export is of course K-pop. The music is everywhere. The band members advertise everything and the fans can be a little crazy.
Record shops can survive purely selling cds and merchandise from only one particular band or company… with personal appearances of a group at one of these stores can have queues around the block.
Was also exposed to the K-pop for the older generation, called “Trot” for some reason….
I’ll find a YouTube clip to show you… but be warned. It’s bad.
Not a good start.
We had knob and tube here too and maybe only 5 years ago I decommissioned some, the owner wanted it left in place for decor so we disturbed it as little as possible.
