Hi everyone,
I've put in an outdoor armoured cable as a spur off the ring main for a friend. This is for a pond pump and LED lighting for the pond. Thought it would be a good idea to protect the spur with a 10A 30mA type A RCBO. All working fine except for when I test the RCBO it does indeed go off but also the RCCB protecting the ring in the consumer unit also goes off. We were hoping only the spur's RCD would go off as my friend is worried that the filter on the pump will block while he's on holiday and it will trip everything in the house (including the fridge) while he's on holiday. He's consumer unit is tiny and only has one RCCB.
Any suggestions gratefully received?
Hi everyone,
Would a 10ma rcbo work in this situation? That is, would it trip before the consumer unit one and therefore prevent the consumer unit one from tripping?
Only way around it is to make the outdoor circuit separate from the indoor circuit.
Otherwise a fault outside will always trip the inside circuit as well.
Unfortunately it wont. I tried. You are talking such low amounts of current that both will still trip. You 'might' find the 10mA trips first but i bet it wont. They are Very likely to trip at the same time.
Why do you think an additional RCD is required?
I'm guessing he's trying to get some form of discrimination to stop the indoor RCD from tripping and he thought that as the new one is 'closer' to the load, it will trip first.
My friend said that the guy who sold him the pump for the fish pond said that the filters have a tendency to block and this can cause the motor to overheat and trigger the trip switch in the house (I think he meant the RCCB in the consumer unit). I thought that if we put a second RCCB on the spur for the outdoor pond cable than it would trigger first without triggering the house RCCB and so things like the refrigerator or freezer stay on.
Damn! Looks like we're going to have to redo the armoured cable, taking it all the way to the consumer unit and then take a branch off the main switch avoiding the indoor RCCB. This is more fiddly and costly than I originally envisaged!
There is that but they are considering a blocked pump which isn't likely to cause a residual fault anyway.
So do you think that if the filter got blocked it would, if anything, cause an overcurrent but not an RCD issue? In which case the 10A RCBO I've put on the spur would actually trip without tripping the 32A ring MCB. So it would probably be ok...?
What size pond pump is it to need a 10A supply? I'm running a 5000lph with up to 3 mtr head pump and thats just 28w
It doesn't need a 10A supply but I the cable is going out to an outdoor socket which could also be used for an electric mower or something so I figured 10A protection
Have you got the model of the pump or a photo? Is it a submerged pump? Most submerged pumps just use a sealed coil and a circular magnet on the impellor. They wont even know if the pump is blocked. Only time they fail is if water gets into the coil.
Apparently it is an oase 6000.
