telectrix
Mentor
yep, just as it gets cold we find our brand new central heating boiler is not capable of working when it's cold outside. works fine in the summer! main problem is that it's a condensing boiler and the condenser pipe goes outsde-- frozen solid. boiler locked out. engineer soonest monday. so had to get it going myself. removed condenser pipe from bottom of boiler, fan heater on all night, bucket under boiler to catch condensed crap. reckon my dog could have installed a better system
Sods law......it's a common problem in this type of weather.....the mrs hairdryer works a treat!
had dryer on it for half an hour last nite. still frozen now. my system is working great. condenses into a bucket inside
Try loads of black coffee and then start p***ing all over the pipes. If it doesn't thaw the pipes out it will put a smile on your face when the plumber has his hands all over them and then goes to lunch;)
Sorry, but they probably are immune to all types of "Crap" anyway and they should get there sooner :D
Strangely enough I had some prat try to blame me for 'leaving the boiler off' and having this as a consequence today. After politely explaining how any condensate would be in the pipe in the first place if the boiler was left off, and asking why indeed the pipes weren't lagged, it turned out it wasn't my fault at all!
Apparently there may be a frost setting on the boiler to stop this happening somehow, but the guy may have been talking balls, I don't know I'm not a boiler plumber; I know how to think in a straight line and everything!
I know/use a good heating Engineer it's a common problem on new boilers, after a certain distance of condense pipe run the diameter of the pipe should increase ( A bit like increasing our CSA ) because the water can't get away quick enough and can back up and freeze, it almost always freezes on the elbow out of the wall as there is a resistance to flow so it slows up, I will check with my engineer but I think it acceptable to run the condense to waste in the house IE a 3/4 connection to trap on sink but I will need to double check on that
Frost stats are used usually for appliances in vulnerable conditions IE in an outbuilding if your house gets that cold to operate that you have seriously cold house dude..sound like a bit of BS to me
Wouldn't suprise me, all anyone else on this job so far has given is BS. They're all bloody 'all rounders', see, apart from me who is just an electrician. Strangely enough I finished up (and keep getting called back to fix their messes) 6 weeks ago, they were supposed to finish 4 weeks ago. They still have (according to them) 3 weeks to go; from what I can see it's at least 5 weeks.
I'm going to go off on one about this job in the arms now, it's been getting to me for weeks.
Condensate pipe should be min 32mm dia if outside and not less than 1:20 fall. Yes it can go into the domestic waste pipe, it's only very mildly acidic. Frost stat won't solve the problem, as someone said, if the boiler's off then there is no condensate to freeze, it is where its not running quick enough to get where it's going before it cools down. Some boiler now only release the condensate in "packets" so it's not dribbling and retains the heat until its in the drain.
Commercial refrigeration engineers use 230v heat tape wrapped in a spiral around drain pipes in cold rooms and walk in freeZers so get a length and get wrapping
I may have missed the point, but I believe he was suggesting that inductive coils around a pipe create resistance and therefore heat to warm the pipe?
Basically yes but even simpler as this is a pre manufactured element tape sold by the metre
