boiler is in garage. frost stat is also in garage. condense pipe goes thru the wall tyo outside. perhaps i should move the frost stat to the outside and fit a radiator on the outside wall, coz it's wher the pipe joins into inch & a half that the freeze occurs. engineer coming monday. i'll make sure he lags it, or fits a coil heater to the pipe.Frost stats are used usually for appliances in vulnerable conditions IE in an outbuilding if your house gets that cold to operate that you have seriously cold house dude..sound like a bit of BS to me
