A
accordfire
Okay, we're all griping about amateurs, and what not.
How many of us can *HONESTLY* say we haven't got (or had) our PC's, TV's, etc running off multiway extensions.....and probably haven't bothered doing the calcs to make sure it's safe either.....
I've just realised, for one thing, that in my haste to put everything together at mum's here, I've loaded quite a bit onto three or four six way trailing sockets, all from one 26A 250V socket outlet (yes, a gentle dig at the thread that got binned).....but I do have my trailing sockets all plugged into one and other. Oops.
Some minor works at weekend, methinks.
Sure mum will love another six doubles in the lounge......
Did the same myself when I had a closer look at the back of the telly. Tv, tv freeview box, dvd, sound system + sub woofer and 2 game consoles all from 1 db socket and extentions. Added extra socket but forgot to notify it, woops.
Heh! I won't tell if you don't.
Funny, though, how we're as bad as the rest when it comes to that - admittedly, easier to add a trailing lead than install a new socket, and to be fair, mostly they get added over time, but it is scary when you stop and think that it's easy to run those things very hot without realising.
Think - TV, DVD, Sky, Sub, PS3/Wii/XBox (or all), Amp, - must be close to the limit.
Same with PC side of things though - PC, Printer, router/Hub, Monitor, USB hub, desk lamp, phone charger (x2), camera charger, speakers......ouch, potentially.
Last week I saw on bbc 1 at 3am a safety advert, the one where the extention with the Xmas tree lights for the outside lights catches on fire. You the man to ask, where would you be able to find out the stats for that? HSE? Is it made public knowledge?
HSE usually publish those kind of stats mate, but also the ONS site - which take some digging about.
I have a few 4-way extensions about the place. I've never seen too much of an issue with them if used properly, to be honest. They're fused, after all. The real beggars that I hate are those cubes you plug in with sockets on all four of their faces.
so my safe block with everything deplugged and stuffed in is a no-no then?
Have one on with Router, printer and cordless phone plugged in, but don't ever think its going to be overloaded!
Yes I have to admit I have one with the tv sky and DVD recorder plugged in. The other one for the Xmas stuff has been put away again until December.
Sent from my iPhone using Tapatalk
My house has an old dorman smith db, no RCD in sight. Have 4 or 5 extension leads running round the house and behind my desk. In my office I had one single socket, so I fixed a patress with a 3 gang fused socket on it, and took leads off it. I have a convector heater plugged into one of the leads.
ross electrical( neweys for those down sauffff) had a nice MK display with 2 2g sockets sat cale connectors and rj45 sockets in one unit I was feart to ask the price and availability
5 in my house BTW Phone chargers in kitchen one sky dvd tv wii under telly from old FCU radial Ikea over unit lights 4 into one and one 6 ganger at hifi phone oc printer ect theres another one in living room corner for digital cameras ect ect ect plugged and unplugged rented house so Im not going to add sockets
on a note I coded over use of multi gand trailing leads as a code 4 other week in an office they had one into every available socket one of which had 4 fed from it for all the mobile chargers ( it was turned off after 2 hrs charging)
Behind my TV cabinet is a war-zone. There are 24 plugs for all the equipment and only two double socket outlets.
1xTV, 1xAmp, 1xradio tuner, 2xcassette decks, 1Equalizer, 1xRecord Deck, 1xDVD player, 1xBluRay player, 1xEntertaiment PC, 1xMonitor, 7xExternal Harddrives, 3XPhone Chargers, 1xGigabyte Ethernet Switch, 1xLamp, 1xSat Decoder.
I started connecting some of the HiFi equipment into multiway blocks but it's still a mess.
my front room burnt down so i don't have any electrical equipment at present, however i did have a 6 way surge behind my tv (not cause of fire)
i just fitted as part of reworks 3 x double where my new elecy stuff will be!!
Yes......I would upload a pic of my jojo 6 way, but you would also then see my skirting mounted socket!!!!!:o
