the neon driver works by passing a small current through a resistor and a neon and then your body to earth. that is why 99% of us will not use them. theoretically, they are safe but if faulty could give you a right belt. theoretically the Titanic was safe but i'm glad i didn't buy a ticket. apaert from which, in decent light you wouldn't see the neon lit so might assume the terminal was dead when it ain't. use a non contact volt stick ( rough idea) and an approved voltage tester such as made by fluke.
Knew you where old but not that old:D:D:D
<P><IMG class=previewthumb alt="" src="http://www.electriciansforums.net/attachment.php?attachmentid=3865&amp;stc=1" attachmentid="3865"></P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>&nbsp;</P>
<P>Scanned copy of instructions for neon. Just remembered this one is in a toolkit in the garage and the top wont screw of to remove the bits from the inside. (will put in bin) Never used never will be used. Love the way it tells you it wont work if you are on a wooden ladder</P>
Yes junior member need to practice uploading ! When will they ban these things. If you were an hse person would you allow anybody to use this
Sorry lads but I can't have all this negativity about these little beauties their little hearts glow when u touch anything lol also they're priceless for marking out boxes in thermal blocks.
That point about a wooden ladder was made in jest but on a serious note, nowadays with all the fiberglass (and other safety type) step ladders around which are rated as non-conductive to 1000v this would be one of the biggest reasons not to use these neon screwdrivers.
Hi test-meter do you charge £10 postage for small single items like megger voltage sticks. The P&P pushes the price above local suppliers :(
Hi pushrod sorry for the late reply, we currently charge £5.00 postage & packaging for smaller items. We are in the process of updating & developing the site and will be revising very soon. There's big things happening just round the corner. I promise you'll all be the first to know about the new changes!
don`t go posting them in the post office in the st johns ctr. i nearly ended up with an armed responce unit and a MI5 interrogation at christmas. she put it on the side next to her comp and till and it started glowing in the packet and making a right racket :D:D her face was a picture and my explanation of what a volt stick was quick to follow before i felt a cold barrel on the back of my neck :D
