Markc
He said he sell's lots of them and has known them to be used on a multitude of different roof structures. I mentioned the "big debate" on here and he wasn't surprised. It's in powering trust into the rubber washer which he said is the issue. Obviously from their construction they are designed to be water proof and be drilled through the finish roof structure. Can be used on slate, metal roofs, flat roofs and others. He recommended use on a fixed material rather than a movable one like pan tile. He also said other installers use the same method as described in earlier posts, so it seems its a case of having some faith in the product. An idea he put to me to sell it to a concerned client is to fix one though the bottom of a lunch box or Tupperware box as a sample and then fill the box with water. Seems a fairly easy thing to demonstrate..........unless it leaks!!!
I also questioned the issue on build regs on the size of the bolt. He did agree the 10% rule but hasn't come up against issues regarding that point so far. We discussed the possibility of applying additional timber to side brace the rafter and fix into that rather than the rafter itself. I will be seeing a build inspector next week on a different job so may ask the question to him and see what his take is.
My opinion now see it is, it looks like it will do the job. Still not looking forward to our first slate roof job but fortunately not to many of them are around this way.
